Designed for superior performance, this keystone jack is available in 9 colors to match housing or allow color-coded port designation in compliance with TIA-606 requirements. Includes 110-type IDC termination with strain relief caps, and comes standard with 50 µinch gold plating on the jack contacts.
C2G keystone jacks will work with C2G wall plates and surface boxes, or any standard keystone and angled multimedia wall plate or patch panel.
Enhanced connectivity
The Cat6 RJ45 UTP Keystone Jack by C2G offers a single port solution for high-speed network connections, ensuring reliable service with its 50µ gold-plated connectors for superior signal quality. -
Easy installation
Featuring both 110 type and LSA (Krone) termination types, this keystone jack is designed for quick and hassle-free installation, making it an ideal choice for various patch panels, outlets, and components. -
Standards compliant
Adhering to the TIA/EIA-606 standards, this keystone jack is built to meet the rigorous requirements of today's networking environments, ensuring compatibility and performance.
- C2G Cat6 RJ45 UTP Keystone Jack - keystone jack
- Product Type
- Keystone jack - CAT 6 - RJ-45
- White
- Port Qty
- 1 port
- TIA/EIA-606
- Product Type
- Enclosure Colour
- White
Cabling & Wiring
- Port Qty
- 1 port
- Termination Type
- 110 type termination, LSA (Krone)
- 50µ gold-plated connectors
- Connector Provided
- 1 x RJ-45 female
- TIA/EIA-606
