Product
Brand
C2G CablesToGo 1-PT VGA W/AUD CAT5E EXTNDR
Quicklinx: 7BCJWS00 Mfr#: 89008
One component of a robust solution that, when paired with a remote unit (part #89010, sold separately), extends your VGA and 3.5mm audio signals up to 300 meters over a Cat5E UTP cable, and distributes the signal to 1 monitor, projector, or display. Ideal for applications when your VGA monitor needs to be placed beyond the average 30 meter VGA cable limitation, and/or you want to split the signal to multiple displays.
Driving a VGA signal over Cat5E helps you take advantage of your UTP cable infrastructure already there for a cost-effective and reliable installation. The TruLink VGA over Cat5 solution is ideal for applications when you need to place your computer in remote location. This is common in digital signage applications for retail stores, houses of worship, classrooms, and boardrooms where you need video presentation in one room, but want the computer to be out of sight and in a safe and secure environment.
With the TruLink VGA + 3.5mm audio over Cat5 extender, you can place your display across the room, on another floor, or in another building while your computer remains in a convenient location.
C2G TruLink 1-Port VGA + 3.5mm Audio over Cat5 Extender- Base Unit - video/audio extender
Video/audio extender
External
Max Transfer Distance
300 m
13 cm x 11 cm x 2.5 cm
367 g
1 year warranty
External
Wired
Max Resolution
1280 x 1024
300 m
1 x network - RJ-45 , 1 x VGA (input) - HD-15 female , 1 x VGA (output) - HD-15 female , 2 x audio (input) - mini jack female
1 x VGA cable - 1.2 m , 1 x audio cable - 1.2 m
RoHS
External power adapter
13 cm
11 cm
2.5 cm
367 g
Limited warranty - 1 year
