C2G CablesToGo 1.8m PWR EXT CBL C13-C14 14AWG
Quicklinx: 7B9KWS00 Mfr#: 81138
£5.87 ex VAT
£7.04 inc VAT
Make your work environment more flexible and efficient. This heavy-duty 14 AWG cord works with monitors, scanners, printers, and other devices that use the 3-pin male-to-female shroud power connector. Plus it features a fully molded design for maximum durability and long life.
The female connector plugs directly into the device while the male connector plugs into another power cord or auxiliary power port on power supply for auto power when the system is turned on.
C2G power extension cable - 1.8 m
Power extension cable
Length
1.8 m
Connector
Power IEC 60320 C13
Connector (Second End)
Power IEC 60320 C14
Rated Voltage
AC 250 V
American Wire Gauge (AWG)
14
Rated Voltage
AC 250 V
Length
1.8 m
Connector
Power IEC 60320 C13
Power IEC 60320 C14
RoHS
Brand: C2G
Price Range Ex VAT: 0 - 50
