Product
C2G Brocade E1MG-SX-OM Compatible SFP (mini-GBIC) Transceiver
Quicklinx: C5TDWS00 Mfr#: 88603
£32.01 ex VAT
£38.41 inc VAT
This Brocade E1MG-SX-OM compatible SFP transceiver provides 1000Base-SX throughput up to 550m over multi-mode fibre (MMF) at a wavelength of 850nm using a LC connector. Digital optical monitoring (DOM) support is also present to allow access to real-time operating parameters. Our transceiver is guaranteed to be 100% compatible with the equivalent Brocade transceiver. This easy to install, hot swappable transceiver has been programmed, uniquely serialized and data-traffic and application tested to ensure that it will initialize and perform identically. It is built to meet or exceed the specifications of Brocade, as well as to comply with multi-source agreement (MSA) standards to ensure seamless network integration.
  • Colour
    Silver
  • Connector 1
    SFP Male
  • Connector 2
    LC Female
  • Warranty
    Lifetime
C2G Brocade E1MG-SX-OM Compatible 1000BASE-SX MMF SFP (Mini-GBIC) Transceiver Module - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - LC multi-mode
Plug-in module
Cabling Type
1000Base-SX
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
GigE
Max Transfer Distance
550 m
Brocade E1MG-SX-OM
29 g
Brocade BigIron RX-16, 32, RX-4, RX-8; FastIron GS 624, 648; FastIron LS FLS624, FLS648; FastIron SuperX SX800; FastIron SX 1600, 800; ICX 6430, 6450, 6610, 6650, 7750; ServerIron ADX 1000, 10000, 4000, 8000; TurboIron 24; VDX 6710, 6720, 6730, 6740
Plug-in module
Silver
Wired
Cabling Type
1000Base-SX
GigE
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
550 m
Digital Optical Monitoring (DOM) support
1 x Ethernet 1000Base-SX - LC multi-mode female x 2
MSA
Brocade E1MG-SX-OM
29 g
Limited warranty - lifetime
Brocade BigIron RX-16, RX-32 AC system, RX-32 DC system, RX-4, RX-8 , Brocade FastIron GS 624P, 624P-DC-EPREM, 624P-DC-STK, 624P-EPREM, 624P-POE, 624P-POE-DC-EPREM, 624P-POE-DC-STK, 624P-POE-EPREM, 624P-POE-STK, 624P-STK, 624P-STK-CXU, 648P, 648P-DC-EPREM, 648P-DC-STK, 648P-EPREM, 648P-POE, 648P-POE-DC-EPREM, 648P-POE-DC-STK, 648P-POE-EPREM, 648P-POE-STK, 648P-STK , Brocade FastIron LS FLS624, FLS624-STK, FLS648, FLS648-EPREM, FLS648-STK , Brocade FastIron SuperX SX800-DC , Brocade FastIron SX 1600, 800 , Brocade ICX 6430-24, 6430-24P, 6430-48, 6430-48P, 6430-C12, 6450-24, 6450-24P, 6450-48, 6450-48P, 6450-C12-PD, 6610-24, 6610-24F, 6610-24P, 6610-48, 6610-48P, 6650-32, 6650-40, 6650-48, 6650-56, 6650-80, 7750-26Q, 7750-48C, 7750-48F , Brocade ServerIron ADX 1000, 10000, 1000-DC, 1000F, 1000-PREM, 1000-SSL, 1000-SSL-PREM, 4000, 8000 , Brocade TurboIron 24x , Brocade VDX 6710, 6720, 6730, 6740, 6740T, 6740T-1G
Brand: C2G
Price Range Ex VAT: 0 - 50
