Product
Brand
C2G Avaya/Nortel AA1419048-E6 SFP mini-GBIC Transceiver
Quicklinx: C5THWS00 Mfr#: 88606
£38.03 ex VAT
£45.63 inc VAT
This Avaya/Nortel AA1419048-E6 compatible SFP transceiver provides 1000Base-SX throughput up to 550m over multi-mode fibre (MMF) at a wavelength of 850nm using a LC connector. Digital optical monitoring (DOM) support is also present to allow access to real-time operating parameters. Our transceiver is guaranteed to be 100% compatible with the equivalent Avaya/Nortel transceiver. This easy to install, hot swappable transceiver has been programmed, uniquely serialized and data-traffic and application tested to ensure that it will initialize and perform identically. It is built to meet or exceed the specifications of Avaya/Nortel, as well as to comply with multi-source agreement (MSA) standards to ensure seamless network integration.
  • Colour
    Silver
  • Connector 1
    SFP Male
  • Connector 2
    LC Female
  • Warranty
    Lifetime
C2G Avaya/Nortel AA1419048-E6 Compatible 1000BASE-SX MMF SFP (Mini-GBIC) Transceiver Module - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - LC multi-mode
Plug-in module
Cabling Type
1000Base-SX
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
GigE
Max Transfer Distance
550 m
1.27 cm x 5.59 cm x 0.76 cm
30 g
Avaya Ethernet Routing Switch 8683XLR, 8683XZR; Secure Router 4134; Nortel Ethernet Routing Switch 8630GBR, 8683POSM; Metro Ethernet Services Unit 1850, 1850-12G-DC, 1850-12GE
Plug-in module
Silver
Wired
Cabling Type
1000Base-SX
GigE
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
550 m
Digital Optical Monitoring (DOM) support
1 x Ethernet 1000Base-SX - LC multi-mode female x 2
MSA
1.27 cm
5.59 cm
0.76 cm
30 g
Limited warranty - lifetime
Avaya Ethernet Routing Switch 8683XLR, 8683XZR , Avaya Secure Router 4134 , Nortel Ethernet Routing Switch 8630GBR, 8683POSM , Nortel Metro Ethernet Services Unit 1850, 1850-12G-DC, 1850-12GE
Brand: C2G
Price Range Ex VAT: 0 - 50
