Product
Brand
C2G ATX 24-pin Power Supply to 20-pin Motherboard Adapter Cable 14cm
Quicklinx: 687SWS00 Mfr#: 81860
This adapter cable by C2G allows you to power your new motherboard by using your existing ATX power supply. It connects a 24-pin ATX power supply to a 20-pin ATX motherboard power connector. Many ATX power supplies and cases ship with a 24-pin power supply connector; use the adapter cable to convert the power supply to use with standard 20-pin ATX motherboards.
C2G power adapter
Power adapter
Connector
Power 24 pin ATX - female
Connector (Second End)
Power 20 pin ATX - male
Power adapter
Connector
RoHS
