AT and PS/2 keyboard adapters allow you to convert 5-pin DIN connections to accommodate a PS/2 style keyboard, using the 6-pin mini-DIN connection. It's the perfect solution for keeping your older keyboard and putting working equipment to good use.
- C2G keyboard adapter - 15 cm
- Keyboard adapter
- Molded
- Length
- 15 cm
- Connector
- 5 PIN DIN - female
- Connector (Second End)
- 6 pin mini-DIN (PS/2 style) - male
- Beige
- Keyboard adapter
- Molded
- Length
- 15 cm
- Beige
- Connector
- RoHS
