C2G AT Female to PS/2 Male Keyboard Adapter Cable 15cm
Quicklinx: 6856WS00 Mfr#: 81498
AT and PS/2 keyboard adapters allow you to convert 5-pin DIN connections to accommodate a PS/2 style keyboard, using the 6-pin mini-DIN connection. It's the perfect solution for keeping your older keyboard and putting working equipment to good use.
C2G keyboard adapter - 15 cm
Keyboard adapter
Molded
Length
15 cm
Connector
5 PIN DIN - female
Connector (Second End)
6 pin mini-DIN (PS/2 style) - male
Beige
Keyboard adapter
Molded
Length
15 cm
Beige
Connector
5 PIN DIN - female
RoHS
