C2G 91.4M VGA+3.5 Over CAT5 BOX RX (300FT)
Quicklinx: D0FNWS00 Mfr#: 89368
Extend a video and audio signal up to 100m at 1920x1200 resolution.
The VGA+3.5mm Audio over Cat5 Box Receiver, when used in conjunction with a transmitter, allows you to extend a VGA and 3.5mm audio signal over two Cat5/Cat5e/Cat6 unshielded twisted pair cables up to 100m without signal degradation at 1920x1200 or 1920x1080 resolutions. This solution is compatible with any operating system and is truly plug and play with no drivers or software required. The transmitter and receiver come in either wall plate or box form factors and are interoperable allowing you to choose the form factors that are best suited for the application. In addition, this solution utilizes phantom power providing you the flexibility to power at either the transmitter or receiver end.
EQ (sharpness) adjustments can be made for optimal signal clarity. Built-In power surge protection and high ground loop immunity ensure high performance signal extension.
C2G TruLink VGA+3.5 Audio over Cat5 Box Receiver - video/audio extender
Video/audio extender (receiver)
External
Transmission Medium
CAT 5
Max Transfer Distance
100 m
249 g
1-year warranty
External
Wired
Max Resolution
1920 x 1200
100 m
1 x VGA - HD-15 female , 2 x network - RJ-45 female , 1 x audio (input) - mini jack female
249 g
Limited warranty - 1 year
