C2G 8in mDP M to DVI F Active 3D 4k BLK
Quicklinx: D0FDWS00 Mfr#: 84318
Colours:
£27.61 ex VAT
£33.13 inc VAT
This adapter allows the Mini DisplayPort video output of a laptop to connect to the DVI-D input of a display and is perfect for applications including displaying video on an HDTV, projector, or monitor in a classroom, on a desktop, or in a meeting room. This Mini DisplayPort to DVI-D active adapter can be used in either DisplayPort single-mode or dual-mode outputs , providing the conversion for a Mini DisplayPort source even when that source does not support DP++. Active Mini DisplayPort conversion is excellent for applications where multiple Mini DisplayPort adapters are required to connect to a single graphics card. This allows every active adapter to interface with a corresponding display. On The Go Enhanced.
Be prepared for any meeting, presentation, or event with the full confidence that you have the right connection in an ultra-compact design. The Mini DisplayPort to DVI-D adapter can connect a Mini DisplayPort equipped laptop or tablet to a projector, monitor, or HDTV with a DVI-D input port. The compact design of this adapter converter makes it a perfect fit for BYOD (Bring Your Own Device) applications in education or corporate environments. Straightforward Install.
This simple plug and play adapter converter does not require drivers for install and the device is powered through Mini DisplayPort bus power, so no additional power adapters are needed. Port Protection.
The dongle-style adapter converter reduces strain on the video port. The cable between the Mini DisplayPort connection and the adapter converter provides strain relief that protects the port from strain damage as cords are moved. Note: When this device is connected to a Mini DisplayPort source device that supports audio and an DVI-D to HDMI Cable with the HDMI connector plugged into a HDMI display device that supports audio both audio and video signal will be transmitted from the source device to the display device. However connecting to a DVI-D display will not allow audio to pass to the display. Note: When this device is connected to a Mini DisplayPort source device that supports 4K signal and an DVI-D to HDMI Cable that supports 4K with the HDMI connector plugged into a HDMI display device that supports 4K video signal full 4K video signal will be transmitted from the source device to the display device. However connecting to a DVI-D display will not allow 4K resolution to pass to the display.
  • Colour
  • Warranty
    3 Years
  • Connector A-1
    Mini DisplayPort Male
  • Connector B-1
    DVI-D Single Link Female
C2G Mini DisplayPort to DVI-D Active Adapter - Video Converter - Black - display cable
Display cable - single link
Triple shielded
Connector
Mini DisplayPort - male
Connector (Second End)
DVI-D - female
3-year warranty
Display cable
Triple shielded
Jacket Material
PVC
TMDS Links
Single link
89 g
Connector
18+1 pin digital DVI (Single-Link) - female
3-year warranty
Brand: C2G
