C2G 8in DP M to HDMI F Active 3D 4K Blk
Quicklinx: D0F7WS00 Mfr#: 84306
25 in stock
£25.80 ex VAT
£30.96 inc VAT
This adapter allows the DisplayPort video output of a laptop to connect to the HDMI input of a display and is perfect for applications including displaying video on an HDTV, projector, or monitor in a classroom, on a desktop, or in a meeting room. This active DisplayPort to HDMI active adapter can be used in either DisplayPort single-mode or dual-mode outputs , providing the conversion for a DisplayPort source even when that source does not support DP++. Active DisplayPort conversion is excellent for applications where multiple DisplayPort adapters are required to connect to a single graphics card. This allows every active adapter to interface with a corresponding display. On The Go Enhanced.
Be prepared for any meeting, presentation, or event with the full confidence that you have the right connection in an ultra-compact design. The DisplayPort to HDMI adapter can connect a DisplayPort equipped laptop or tablet to a projector, monitor, or HDTV with a HDMI input port. The compact design of this adapter converter makes it a perfect fit for BYOD (Bring Your Own Device) applications in education or corporate environments. Straightforward Install.
This simple plug and play adapter converter does not require drivers for install and the device is powered through DisplayPort bus power, so no additional power adapters are needed. Port Protection.
The dongle-style adapter converter reduces strain on the video port. The cable between the DisplayPort connection and the adapter converter provides strain relief that protects the port from strain damage as cords are moved.
  • Colour
  • Warranty
    3 Years
  • Connector A-1
    DisplayPort Male
  • Connector B-1
    HDMI Female
C2G DisplayPort to HDMI Active Adapter 4K UHD - Video Converter - Black - video adapter - DisplayPort / HDMI
Cable
Video adapter - DisplayPort / HDMI
Triple shielded
Connector
DisplayPort - male
Connector (Second End)
HDMI - female
4K support
3-year warranty
Cable Type
Video adapter - 4K support
Interface Supported
DisplayPort / HDMI
Triple shielded
Jacket Material
PVC
Connector
20 pin DisplayPort - male
19 pin HDMI Type A - female
89 g
Limited warranty - 3 years
Brand: C2G
Price Range Ex VAT: 0 - 50
