C2G 8-Port UXGA Monitor Splitter/Extender (Male Input)
Quicklinx: 7BCPWS00 Mfr#: 89014
£59.58 ex VAT
£71.49 inc VAT
The TruLink 8-Port UXGA splitter/extender (also known as a VGA video splitter) is a robust hardware solution that can distribute any video signal to 8 different video outputs, while maintaining brilliant picture quality. Though powerful, this splitter is easy to use; just attach the cables, and you're ready to go! There is no software required, or complicated interface cards to install. This monitor splitter not only distributes, but also boosts your high resolution video signal up to 65 meters.
C2G 8-Port UXGA Monitor Splitter/Extender (Male Input) - video splitter - 8 ports
Video splitter - 8 ports
19.6 cm x 7 cm x 4 cm
0.72 kg
1-year warranty
Enclosure Type
Desktop
Max Resolution
2048 x 1536 @ 75 Hz
Max Video Bandwidth
300 MHz
Status Indicators
Power, active
8 x VGA output HD-15 , 1 x VGA input HD-15
External power adapter
19.6 cm
7 cm
4 cm
0.72 kg
Limited warranty - 1 year
Brand: C2G
Price Range Ex VAT: 50 - 100
