The Pro Series UXGA monitor cable with 3.5mm audio from C2G is the ideal high performance solution for quickly connecting your PC to a video display system with speakers. Use this cable with projectors, flat-screen monitors, KVM switches with audio, speakers, or a microphone. Designed to support resolutions up to 1600 x 1200, this cable can support distances up to 30.48 meters without conditioning the signal. It is ideal for video presentations, projector applications and classroom environments.
- C2G Pro Series UXGA - display / audio cable kit - 7 m
- Display / audio cable kit
- Technology
- Shielded
- Length
- 7 m
- Connectors
- HD-15 (VGA) - male , Mini-phone stereo 3.5 mm - male
- Connectors (Second End)
- RoHS
- Technology
- Shielded
- Length
- 7 m
- Connectors
- 15 pin HD D-Sub (HD-15) - male , Mini-phone stereo 3.5 mm - male
- Cable Kit Details
- 1 x VGA gender changer - 15 pin HD D-Sub (female) to 15 pin HD D-Sub (female) , 1 x display / audio cable - 15 pin HD D-Sub (male), mini-phone stereo 3.5 mm (male) to 15 pin HD D-Sub (male), mini-phone stereo 3.5 mm (male) - 7 m
- RoHS
