C2G 7m Cat5E 350 MHz Snagless Patch Cable - Red
Quicklinx: 6BMLWS00 Mfr#: 83226
Perfect for your home office or a large installation project, ehanced Cat5E 350MHz snagless patch cables from C2G distribute data, voice and video. These cables handle bandwidth intensive applications up to 350MHz and meet all Cat5E TIA/EIA standards. The molded, snag-free boot prevents unwanted cable snags during installation and provides extra strain-relief.
  • High-quality connectivity
    The Cat5e Booted Unshielded (UTP) Network Patch Cable by C2G is designed with a high-quality PVC jacket and gold-plated connectors to ensure reliable connectivity and durability. Its American Wire Gauge (AWG) of 24 supports efficient data transmission, making it a dependable choice for networking needs.
  • Enhanced performance
    With a tested frequency of up to 350 MHz, this patch cable is engineered to enhance the performance of your network. The T568B wiring scheme and the presence of 4 pairs per cable ensure that it can handle high-speed data transfer with ease, making it suitable for various applications.
  • Universal compatibility
    Designed to be compatible with PCs, this network patch cable features male RJ-45 connectors on both ends, ensuring it can be easily integrated into any existing network setup. Its compliance with RoHS standards also ensures that it meets global regulatory requirements, further emphasizing its versatility and safety.
C2G Cat5e Booted Unshielded (UTP) Network Patch Cable - patch cable - 7 m - red
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded, snagless, stranded
Length
7 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Red
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
7 m
Red
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 350 MHz
