C2G 7m Cat5E 350 MHz Crossover Patch Cable - Grey
Quicklinx: 6BNGWS00 Mfr#: 83286
Length: 7m
Colour: Grey
£4.47 ex VAT
£5.36 inc VAT
This Cat5e network crossover patch cable is an ideal solution for connecting two computer to share files or data. The crossed pin configuration allows two computers to be connected peer-to-peer without the need for a hub or switch. This cable may also be used to connect network switches and hubs without an uplink port to other switches and hubs. This cable is constructed to meet all Cat5e TIA/EIA standards, and has been designed to drastically reduce both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality cable and a shortened body plug, this design minimizes Near-End Crosstalk (NEXT) levels.
C2G Cat5e Non-Booted Unshielded (UTP) Network Crossover Patch Cable - crossover cable - 7 m - grey
Crossover cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Stranded, uniboot
Length
7 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Grey
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Stranded, uniboot
Length
7 m
Grey
Connector
RJ-45 - male
RJ-45 - male
Up to 350 MHz
Length: 7m
Colour: Grey
Brand: C2G
