C2G 7m 3.5mm M/F Stereo Audio Extension Cable (PC-99 Colour-Coded)
Quicklinx: 67R5WS00 Mfr#: 80103
3.5mm stereo audio cable from C2G is specifically designed for extending the distance of your existing 3.5mm audio cable. The 3.5mm audio cable connects the PC sound card, portable CD player or any mini-stereo audio device with 3.5mm jacks to multimedia speakers. The cable features two 29-gauge stranded conductors and a drain wire, which are tinned to resist oxidation.
C2G audio extension cable - 7 m
Cable
Audio extension cable
Shielded
American Wire Gauge (AWG)
29
Length
7 m
Connector
Mini-phone stereo 3.5 mm - male
Connector (Second End)
Mini-phone stereo 3.5 mm - female
Colour-coded connectors, stranded conductor, moulded
Cable Type
Shielded
29
Shielding Material
Foil
Length
7 m
Plated Connector
Nickel
Connector
RoHS
