C2G 5m USB 3.0 USB-A Male to USB-A Female Active Extension Cable
Quicklinx: CKVMWS00 Mfr#: 89943
Length: 5m
£25.31 ex VAT
£30.37 inc VAT
Extend a USB 3.0 cable up to 5 metres (15ft) from a desktop, laptop or remote terminal to a interactive display, hard drive or other peripheral device with this USB 3.0 active extension cable to achieve high-speed data transfer at longer distances. This cable supports all USB 3.0 functionality, including data transfer rates up to 5 Gbps, which allows you to deliver data quicker with the ability to sync, download pictures or upload new apps at maximum speed. Additionally, the use of USB bus power eliminates the need for external power adapters. This simple, one connection solution allows for quick, plug-and-play installation - encouraging productivity and simplifying device connectivity. You can connect up to two active extension cable end-to-end to achieve up to 10 metres extension in total. Note: Backwards compatibility ensures both USB 1.1 and 2.0 speed USB devices will function equally as well with this extension.
  • Connector 1
    USB-A Male
  • Connector 2
    USB-A Female
C2G 5m USB 3.0 USB-A Male to USB-A Female Active Extension Cable - USB extension cable - USB Type A to USB Type A - 5 m
USB extension cable
Double shielded
Active cable (signal regeneration)
Length
5 m
Connector
9 pin USB Type A - male
Connector (Second End)
9 pin USB Type A - female
Rated Voltage
30 V
USB / USB 2.0 / USB 3.0
3-year warranty
USB extension cable
Double shielded
Shielding Material
Jacket Material
PVC
Rated Voltage
30 V
Length
5 m
320 g
Connector
USB / USB 2.0 / USB 3.0, Plug and Play
3-year warranty
Length: 5m
Brand: C2G
Price Range Ex VAT: 0 - 50
