Product
Brand
C2G 5m USB 2.0 A Male to A Female Active Extension Cable
Quicklinx: 6876WS00 Mfr#: 81655
Length: 5m
More than 50 in stock
£12.00 ex VAT
£14.40 inc VAT
Standard delivery Delivered within 3-5 working days
This extension cable actively buffers the incoming and outgoing signals to ensure compliance with USB's 2.0 specification for electrical and timing minimums. You can connect up to 4 active extension cables end-to-end to achieve up to 19.8 metres total extension! Both low and high speed USB devices will function equally well with this extension.
C2G USB Active Extension Cable - USB extension cable - 5 m
USB extension cable
Active cable (signal regeneration)
Length
5 m
Connector
4 pin USB Type A - male
Connector (Second End)
4 pin USB Type A - female
USB / USB 2.0
USB extension cable
Length
5 m
Connector
USB / USB 2.0, Plug and Play, RoHS
Length: 5m
Brand: C2G
Price Range Ex VAT: 0 - 50
