This extension cable actively buffers the incoming and outgoing signals to ensure compliance with USB's 2.0 specification for electrical and timing minimums. You can connect up to 4 active extension cables end-to-end to achieve up to 20 meters total extension! Both low and high speed USB devices will function equally well with this extension.
- C2G USB Active Extension Cable - USB extension cable - USB to USB - 5 m
- Active cable (signal regeneration)
- Length
- 5 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 4 pin USB Type A - female
- USB / USB 2.0
- Beige
- 1-year warranty
- Length
- 5 m
- Beige
- Connector
- USB / USB 2.0
- 1-year warranty
