Product
C2G 5M USB 2.0 A/A Active Ext. Cbl
Quicklinx: 6C56WS00 Mfr#: 81665
This extension cable actively buffers the incoming and outgoing signals to ensure compliance with USB's 2.0 specification for electrical and timing minimums. You can connect up to 4 active extension cables end-to-end to achieve up to 20 meters total extension! Both low and high speed USB devices will function equally well with this extension.
C2G USB Active Extension Cable - USB extension cable - 5 m
USB extension cable
Active cable (signal regeneration)
Length
5 m
Connector
4 pin USB Type A - male
Connector (Second End)
4 pin USB Type A - female
USB / USB 2.0
Beige
1 year warranty
USB extension cable
Length
5 m
Beige
Connector
USB / USB 2.0
1 year warranty
