Your basket is empty
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915LWS00 Mfr#: 80555
The Select High Speed HDMI Cable with Ethernet is the perfect solution for connecting multimedia source devices in home theatre, desktop or commercial audio video applications requiring high speed HDMI features. The CL2 rated cable jacket is designed to meet the requirements for in-wall installations. The Ethernet capabilities of the cable allow a user to connect multiple Ethernet enabled HDMI devices through a single Ethernet connection. Connector 1: (1) HDMI Male Connector 2: (1) HDMI Male.
C2G/Legrand Select High Speed HDMI with Ethernet - HDMI with Ethernet cable - 5 m
Cable
Shielded
American Wire Gauge (AWG)
28
Length
5 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
Cable Type
Shielded
28
Jacket Material
PVC
Shielding Material
Aluminium foil with braid
Impedance
100 Ohm
Length
5 m
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
UL
Limited warranty - lifetime
