C2G 5m DB9 M/F Extension Cable - Black
Quicklinx: 681XWS00 Mfr#: 81379
Length: 5m
Type: Serial
27 in stock
£8.34 ex VAT
£10.00 inc VAT
Don't sacrifice convenience when determining where to place your hardware. A DB9 extension cable can give you the flexibility to extend a computer peripheral wherever you need it. Each extension cable comes fully shielded to prevent unwanted EMI/RFI interference, and the fully snagless cable design delivers excellent strain relief. Connector thumbscrews provide a quick and easy connection every time. All lines are wired straight through.
  • Warranty Details
    This product carries a lifetime warranty
  • Product Colour
C2G serial extension cable - 5 m
Serial extension cable
Shielded
Molded, thumbscrews
Length
5 m
Connector
9 pin D-Sub (DB-9) - female
Connector (Second End)
9 pin D-Sub (DB-9) - male
Shielded
Molded, thumbscrews
Length
5 m
Connector
RoHS
Length: 5m
Type: Serial
Brand: C2G
Price Range Ex VAT: 0 - 50
