Don't sacrifice convenience when determining where to place your hardware. A DB9 extension cable can give you the flexibility to extend a computer peripheral wherever you need it. Each extension cable comes fully shielded to prevent unwanted EMI/RFI interference, and the fully snagless cable design delivers excellent strain relief. Connector thumbscrews provide a quick and easy connection every time. All lines are wired straight through.
- C2G serial extension cable - 5 m
- Serial extension cable
- Technology
- Shielded
- Molded, thumbscrews
- Length
- 5 m
- Connector
- 9 pin D-Sub (DB-9) - female
- Connector (Second End)
- 9 pin D-Sub (DB-9) - male
- Black
- Technology
- Shielded
- Length
- 5 m
- Black
- Connector
- RoHS
