C2G 5m 18 AWG Computer Power Extension Cord (IEC320C13 to IEC320C14)
GREAT VALUE POWER CABLING FROM CABLES TO GO!
Quicklinx: 63NFWS00 Mfr#: 88506
Type: Power
£6.36 ex VAT
£7.63 inc VAT
Make your work environment more flexible and efficient. This heavy-duty 18 AWG cord is designed to work with monitors, scanners, printers, and other devices that use the 3-pin male-to-female shroud power connector. Plus it features a fully moulded design for maximum durability and long life. The female connector plugs directly into the device while the male connector plugs into another power cord.
C2G Computer Power Cord Extension - power extension cable - power IEC 60320 C13 to IEC 60320 C14 - 5 m
Power extension cable
Length
5 m
Connector
Power IEC 60320 C13
Connector (Second End)
Power IEC 60320 C14
Rated Voltage
AC 250 V
American Wire Gauge (AWG)
16
Rated Voltage
AC 250 V
Length
5 m
Connector
Power IEC 60320 C13
Power IEC 60320 C14
RoHS
Type: Power
Brand: C2G
