C2G 455883-B21 10GBase-SR SFP+ Transceiver
Quicklinx: CJ82WS00 Mfr#: 89109
This HP 455883-B21 compatible SFP+ transceiver provides 10GBase-SR throughput up to 300m over multi-mode Fibre (MMF) at a wavelength of 850nm using a LC connector. Digital optical monitoring (DOM) support is also present to allow access to real-time operating parameters. Our transceiver is guaranteed to be 100% compatible with the equivalent HP transceiver. This easy to install, hot swappable transceiver has been programmed, uniquely serialized and data-traffic and application tested to ensure that it will initialize and perform identically. It is built to meet or exceed the specifications of HP, as well as to comply with multi-source agreement (MSA) standards to ensure seamless network integration.
  • Colour
    Silver
  • Connector 1
    SFP Male+
  • Connector 2
    LC Female
  • Warranty
    Lifetime
C2G - SFP+ transceiver module - 10 GigE
SFP+ transceiver module - LC multi-mode
Plug-in module
Cabling Type
10GBase-SR
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
10 GigE
Max Transfer Distance
300 m
HP 455883-B21
1.27 cm x 6.35 cm x 0.76 cm
90.7 g
HPE D2D4324; Apollo 4200 Gen10; BLc3000 Enclosure; BLc7000 Single-Phase Enclosure; BLc7000 Three-Phase Enclosure; Edgeline e920, e920d; ProLiant DL360p Gen8, DL980 G7, e910t 2U, XL170r Gen10, XL450 Gen10; SimpliVity 380 Gen10, 380 Gen9; Virtual Connect Flex-10
Plug-in module
Silver
Wired
Cabling Type
10GBase-SR
10 GigE
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
300 m
Digital Optical Monitoring (DOM) support
1 x Ethernet 10GBase-SR - LC multi-mode female x 2
MSA
HP 455883-B21
1.27 cm
6.35 cm
0.76 cm
90.7 g
Limited warranty - lifetime
HPE D2D4324 Capacity Upgrade , HPE Apollo 4200 Gen10 384TB 25Gb Capacity Server for Cohesity DataPlatform , HPE BLc3000 Enclosure , HPE BLc7000 Single-Phase Enclosure w/2 Power Supplies and 4 Fans w/8 Insight Control Environment Trial Licenses, w/6 Power Supplies and 10 Fans w/16 Insight Control Environment Licenses , HPE BLc7000 Three-Phase Enclosure w/6 Power Supplies and 10 Fans w/16 Insight Control Environment Licenses , HPE Edgeline e920, e920d , HPE ProLiant DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 Entry, DL360p Gen8 High Performance, DL980 G7, e910t 2U Node, XL170r Gen10 24TB Server Add-on for Cohesity DataPlatform, XL170r Gen10 36TB Server Add-on for Cohecity DataPlatform, XL450 Gen10 200TB Server for Cohesity DataPlatform, XL450 Gen10 400TB Server for Cohesity DataPlatform, XL450 Gen10 700TB Server for Cohesity DataPlatform , HPE SimpliVity 380 Gen10 Node, 380 Gen9 Node , HPE Virtual Connect Flex-10
