The TruLink 4-Port UXGA splitter/extender (also known as a VGA video splitter) is a robust hardware solution that can distribute any video signal to 4 different video outputs, while maintaining brilliant picture quality. Though powerful, this splitter is easy to use; just attach the cables, and you're ready to go! There is no software required, or complicated interface cards to install. This monitor splitter not only distributes, but also boosts your high resolution video signal up to 65 meters.
- C2G 4-Port UXGA Monitor Splitter/Extender (Male Input) - video splitter - 4 ports
- Video splitter - 4 ports
- Power
- AC 120/230 V (50/60 Hz)
- 18 cm x 8.5 cm x 2 cm
- 428 g
- Black
- 1 year warranty
- Enclosure Type
- Desktop
- Max Resolution
- 2048 x 1536 @ 75 Hz
- Max Video Bandwidth
- 350 MHz
- Status Indicators
- Power, active
- 4 x VGA output HD-15 , 1 x VGA input HD-15
- Power Device
- External power adapter
- Voltage Required
- Black
- 18 cm
- 8.5 cm
- 2 cm
- 428 g
- Limited warranty - 1 year
