Product
C2G 4-Port USB 2.0 Aluminum Hub
Reduced Price - Whilst Stocks Last!
Quicklinx: 7BB4WS00 Mfr#: 81645
Type: USB Hub
Interface: USB 2.0
Speed: 480Mbps
Ports: 4
Form Factor: External
Hurry, only 1 left in stock!
£14.78 ex VAT
£17.73 inc VAT
Express delivery Order within the next 18 hours for delivery on Thursday
The aluminum hub conveniently adds four high speed USB 2.0 ports to your desktop or laptop computer. The slim form factor saves space while the port placement and hard-mountable metal base keep the hub in place even when several USB devices are connected. The removable aluminum base can be hard-mounted to your desk. The hub easily slides from that base, and makes it convenient for travel as well.
This hub can be self-powered from the USB port, or utilize an AC power supply adapter. Downstream ports have automatic connect and speed detection plus overcurrent protection with auto recovery. Add additional hubs to daisy-chain up to 127 devices; this hub delivers high speed data transfers up to 480Mbps. Whether you are downloading or transferring spreadsheets, MP3 files, digital pictures, or video streams, the 4-port hub makes connecting several high speed USB 2.0 devices hassle-free.
C2G 4-Port USB 2.0 Aluminum Hub - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x USB 2.0
USB powered
USB 1.1, USB 2.0
Apple MacOS X or later, Microsoft Windows 98SE/2000/ME/XP, Microsoft Windows Vista
1-year warranty
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
4 x USB 2.0
USB powered
USB 1.1, USB 2.0
4 x USB 2.0 Type A , 1 x mini-USB 2.0 Type B
External power adapter
1 x USB cable - 91 cm
FCC, RoHS
Limited warranty - 1 year
Type: USB Hub
Interface: USB 2.0
Speed: 480Mbps
Ports: 4
Brand: C2G
Stock Status: Clearance
Price Range Ex VAT: 0 - 50
