C2G 4.5m (15ft) USB C to VGA Adapter Cable - Black
Quicklinx: DWL6WS00 Mfr#: 82386
£39.09 ex VAT
£46.90 inc VAT
The USB-C to VGA Adapter Cable provides a fast and reliable connection between a USB Type C enabled Chromebook, laptop, tablet or other device and a monitor, projector or other display with a VGA input – making it an ideal solution for the office, work space applications or home use. This adapter utilises the audio/video capabilities built into USB Type-C ports to feed a video signal to the connected display and supports up to a 1920x2100 at 60Hz resolution, allowing it to deliver a high-quality video image. Additionally, the USB-C connector has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port. The cable form factor of this adapter provides a simple and convenient one-cable solution that eliminates the need for a separate adapter or additional cabling.
  • Colour
  • Warranty
    3 Years
  • Connector A
    USB-C Male
  • Connector B
    VGA Male
C2G 4.5m (15ft) USB C to VGA Adapter Cable - Video Adapter - Black - external video adapter - black
External video adapter
Bus Type
USB-C
Max Resolution
1920 x 1200
VGA (male connector)
Length
4.5 m
Enclosure Colour
3-year warranty
Bus Type
USB-C
Max Resolution
1920 x 1200 at 60 Hz
Plug and Play, RoHS 2 (2011/65/EU)
Length
4.5 m
Enclosure Colour
Limited warranty - 3 years
45 °C
Brand: C2G
