Brand
C2G 4.5m (15ft) USB C to HDMI Adapter Cable 4K - Black
Quicklinx: DWL3WS00 Mfr#: 82383
Select:
Hurry, only 1 left in stock!
£46.80 ex VAT
£56.16 inc VAT
Experience 4K ULTRA HD displays with this USB-C to HDMI Adapter Cable which provides a fast and reliable connection between a USB Type C enabled Chromebook, laptop, tablet or other device and an HDTV, projector or other HDMI-equipped display – making it an ideal solution for the office, work space applications or home use. Supporting resolutions up to 4K @ 60Hz, which is four times the clarity of 1080p, this cable offers high quality, ULTRA HD video image. Additionally, the USB-C connector has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port. The cable form factor of this adapter provides a simple and convenient one-cable solution that eliminates the need for a separate adapter or additional cabling.
  • Colour
  • Warranty
    3 Years
  • Connector 1
    (1) USB-C Male
  • Connector 2
    (1) HDMI Male
C2G 4.5m (15ft) USB C to HDMI Adapter Cable 4K - Audio / Video Adapter - Black - external video adapter - black
External video adapter
Bus Type
USB-C
Max Resolution
3840 x 2160
HDMI (male connector)
Length
4.5 m
Enclosure Colour
3-year warranty
Bus Type
USB-C
Max Resolution
3840 x 2160 at 30 Hz
Plug and Play, RoHS 2 (2011/65/EU)
Length
4.5 m
Enclosure Colour
Limited warranty - 3 years
45 °C
Brand: C2G
Stock Status: In stock
