C2G 3m Value Series™ High Speed with Ethernet HDMI® Micro Cable
Quicklinx: 801NWS00 Mfr#: 82012
This High-Speed HDMI to Micro HDMI Cable is perfect for connecting your HDMI Micro-equipped smartphone, tablet or other portable device to your HDTV or HDMI-capable display for home theatre or desktop applications, including high quality streaming of live sports, movies and more – straight from your device. This Cable provides a reliable connection between more modern technology and existing HDMI-enabled devices supporting the latest HDMI capabilities, including ULTRA HD and video resolutions up to 4K (2160p). The Ethernet capabilities of the cable allow a user to connect multiple Ethernet enabled HDMI devices through a single Ethernet connection for accessing interactive online content or updating device firmware.
  • HDMI Feature Note
    Both the source device and display must support an HDMI feature in order to pass that feature through this cable
  • Multi-Stream Audio
    Simultaneous delivery of multi-stream audio to multiple users (up to 4)
  • Wide Angle Support
    Support for the wide angle theatrical 21:9 video aspect ratio
  • Dynamic Synchronization
    Dynamic synchronization of video and audio streams
  • CEC Control
    CEC extensions for control of consumer electronics devices through a single control point
  • Colour
  • Warranty
    Lifetime
  • Connector 1
    (1) HDMI Male
  • Connector 2
    (1) HDMI Micro Male
C2G Value Series 3m High Speed HDMI to HDMI Micro Cable with Ethernet - 4K - UltraHD - HDMI cable with Ethernet - 3 m
Cable
Length
3 m
Connector
HDMI - male
Connector (Second End)
19 pin micro HDMI Type D - male
Moulded
Cable Type
Jacket Material
PVC
Length
3 m
Plated Connector
Gold
Moulded
Connector
19 pin HDMI Type A - male
Limited warranty - lifetime
