Product
C2G 3m USB 3.0 (USB 3.1 Gen 1) USB-C to USB-Micro B Cable M/M
Quicklinx: CHP4WS00 Mfr#: 88864
Length: 3m
£13.59 ex VAT
£16.30 inc VAT
This USB 3.0 (USB 3.1 Gen 1) USB-C to USB-Micro B cable is the perfect solution for connecting a smartphone, tablet, or other device that has a USB-Micro B port to a computer, tablet or other device that has a USB Type-C port for USB 3.0 (USB 3.1 Gen 1) communication. The colour-coded USB Type-C connector allows this cable to be easily identified as a USB 3.0 (USB 3.1 Gen 1) cable and differentiated from other cables which may support a different feature set. The USB Type-C connector is smaller than traditional USB connector and features a symmetrical design which allows it to be easily connected on the first try. Additionally, the durability of the USB Type-C connector allows for up to 10,000 connection cycles. This cable supports a data rate up to 5Gbps for data transfer and sync with 5 volts and 1 amp of power for device operation and charging.
  • Warranty
    Lifetime
  • Colour
  • Length
    3 meter
C2G USB-C cable - 3 m
USB-C cable
Sync and charge, colour-coded connectors, nickel plated shell
Length
3 m
Connector
24 pin USB-C - male
Connector (Second End)
10 pin Micro-USB Type A - male
USB 3.0/ USB 3.1
USB-C cable
American Wire Gauge (AWG)
24/30
Plated Connector
Gold
Length
3 m
Connector
24 pin USB-C - male
USB 3.0/ USB 3.1
Length: 3m
Brand: C2G
Price Range Ex VAT: 0 - 50
