The Ultima USB cable optimizes style, quality, and value in a cable specially designed for high performance. Just plug-and-play for USB devices with the mini-b port, and this cable will deliver high speed data transfer up to 480 Mbps. Two 24 AWG and two 28 AWG heavy duty wires provide the proper current to your USB device. Dual foil and braid shielding reduces EMI/RFI interference while twisted pair construction helps reduce crosstalk thus ensuring high speed, error-free data transfer. The sleek design of the molded connectors makes them easy to grip. The metal connector shield helps to meet FCC requirements on EMI/RFI interference, while a solder-to-connector shell and cable braid create an end-to-end shielding solution for a noise-free connection. 24k gold-plated connectors provide maximum corrosion resistance for error-free data transfer. The charcoal gray cable jacket not only matches your case but disappears behind your desk leaving a clean organized look. Finally, an ultra-flexible jacket makes installation easy.
- C2G Ultima 3m USB 2.0 A to Mini-B Cable (9.8ft) - USB cable - 3 m
- USB cable
- Technology
- Double shielded twisted pair
- Molded, EMI/RFI protection
- Length
- 3 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- Mini-USB Type B - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB cable
- Technology
- Shielding Material
- Dual foil with braid
- Plated Connector
- Gold
- Length
- 3 m
- Black
- 308 g
- Connector
- USB / USB 2.0, Plug and Play, FCC
