C2G 3m USB 2.0 A to Mini B Cable
Quicklinx: DWR9WS00 Mfr#: 89652
Length: 3m
Hurry, only 2 left in stock!
£3.83 ex VAT
£4.59 inc VAT
The Ultima USB cable optimizes style, quality, and value in a cable specially designed for high performance. Just plug-and-play for USB devices with the mini-b port, and this cable will deliver high speed data transfer up to 480 Mbps. Two 24 AWG and two 28 AWG heavy duty wires provide the proper current to your USB device. Dual foil and braid shielding reduces EMI/RFI interference while twisted pair construction helps reduce crosstalk thus ensuring high speed, error-free data transfer. The sleek design of the molded connectors makes them easy to grip. The metal connector shield helps to meet FCC requirements on EMI/RFI interference, while a solder-to-connector shell and cable braid create an end-to-end shielding solution for a noise-free connection. 24k gold-plated connectors provide maximum corrosion resistance for error-free data transfer. The charcoal gray cable jacket not only matches your case but disappears behind your desk leaving a clean organized look. Finally, an ultra-flexible jacket makes installation easy.
  • Colour
  • Warranty
    Lifetime
  • Length
    3 metres
C2G Ultima 3m USB 2.0 A to Mini-B Cable (9.8ft) - USB cable - 3 m
USB cable
Double shielded twisted pair
Molded, EMI/RFI protection
Length
3 m
Connector
4 pin USB Type A - male
Connector (Second End)
Mini-USB Type B - male
USB / USB 2.0
USB cable
Shielding Material
Dual foil with braid
Plated Connector
Gold
Length
3 m
308 g
Connector
USB / USB 2.0, Plug and Play, FCC
Length: 3m
Brand: C2G
Price Range Ex VAT: 0 - 50
