C2G 3m USB 2.0 A Male to Micro-USB B Male Cable
Quicklinx: 9Y4KWS00 Mfr#: 81702
£9.37 ex VAT
£11.24 inc VAT
Connect to mobile phones, GPS systems, PDAs, OTG devices and digital cameras by using the micro-USB connection on your computer or other USB device. The micro-USB connector is smaller and thinner than the previous USB Mini-b standard while offering better performance. Its small form factor is ideal for today's compact portable devices while easily transferring data or charging your device at a transfer speed up to 480 Mbps. This cable is compliant with USB 2.0 specifications and the On-The-Go supplement.
  • Warranty
    Lifetime
  • Colour
  • Length
    3 meter
C2G USB 2.0 A to Micro B Cable - USB cable - 1 m
USB cable
Length
1 m
Connector
5 pin Micro-USB Type B - male
Connector (Second End)
4 pin USB Type A - male
USB 2.0 On-The-Go
USB cable
Length
1 m
Connector
USB 2.0 On-The-Go
Brand: C2G
Price Range Ex VAT: 0 - 50
