C2G 3m Mini DisplayPort to DisplayPort Adapter Cable M/M - White
Quicklinx: 9MRHWS00 Mfr#: 84299
Select:
This adapter cable is an ideal solution for connecting the Mini DisplayPort output of a small laptop or tablet to a computer monitor which accepts a DisplayPort input. This cable carries a digital audio/video signal and supports up to a 4k resolution. Built to DisplayPort 1.2 standards, this cable meets the requirements of high performance applications.
  • Resolution Support
    Supports up to a 4k resolution
  • Colour
    White
  • DisplayPort Specification
C2G 3m Mini DisplayPort to DisplayPort Adapter Cable 4K UHD - White - DisplayPort cable - 3 m
DisplayPort cable
Length
3 m
Connector
Mini DisplayPort - male
Connector (Second End)
DisplayPort - male
White
DisplayPort cable
Length
3 m
White
Connector
20 pin DisplayPort - male
DisplayPort 1.2
