IEEE 1394 FireWire cables from C2G provide transfer speeds up to 400 Mbps. Digital video camcorders, scanners, printers, video conferencing cameras and fixed-disk drives can all share a common bus connection to one PC, as well as to each other. With Windows Me or Apple's FireWire Target Disk Mode you can use an IEEE-1394 cable to connect two computers together to allow for file sharing. Use the 6-pin cable to provide power to devices and the 4-pin for non-powered devices.
- C2G - IEEE 1394 cable - 4 PIN FireWire to 6 PIN FireWire - 3 m
- IEEE 1394 cable
- Molded
- Length
- 3 m
- Connector
- 4 PIN FireWire - male
- Connector (Second End)
- 6 PIN FireWire - male
- IEEE 1394
- IEEE 1394 cable
- Molded
- Length
- 3 m
- Connector
- IEEE 1394, Plug and Play, RoHS
