C2G 3m DisplayPort Male to Single Link DVI-D Male Adapter Cable
Quicklinx: 9MRSWS00 Mfr#: 84330
Length: 3m
Select:
£26.68 ex VAT
£32.01 inc VAT
This adapter cable is an ideal solution for connecting the DisplayPort output of a laptop to a computer monitor which accepts a DVI-D input. This cable carries a digital video signal, supports up to a 1920x1200 resolution and meets the requirements of high performance applications.
  • Seamless connectivity
    Designed for optimal performance, the 3 m DisplayPort to Single Link DVI-D Adapter Cable M/M ensures a seamless connection between your DisplayPort-equipped PC and DVI-D single link display devices. This cable supports high-definition video from your computer to a monitor for video streaming or gaming; connect and configure your monitor for an extended desktop or mirrored displays
  • High-quality construction
    Crafted with the user in mind, this black DisplayPort to DVI adapter cable features a 20-pin DisplayPort male connector on one end and an 18+1 pin digital DVI (Single-Link) male connector on the other. The robust construction ensures durability and reliability for long-term use
C2G 3m DisplayPort to Single Link DVI-D Adapter Cable M/M - DP to DVI - Black - DisplayPort cable - 3 m
DisplayPort cable - single link
Length
3 m
Connector
DisplayPort - male
Connector (Second End)
DVI-D - male
DisplayPort cable
TMDS Links
Single link
Length
3 m
Connector
20 pin DisplayPort - male
18+1 pin digital DVI (Single-Link) - male
Length: 3m
Brand: C2G
