This cable is an ideal solution for connecting the DisplayPort output of a laptop to a computer monitor which accepts a DisplayPort input. This cable carries a digital audio/video signal and the connectors feature latches which secure the cable in the port. Support of a High Bit Rate (HBR) bandwidth means that this cable can carry up to a 4k resolution. Built to DisplayPort 1.2 standards, this cable meets the requirements of high performance applications.
Resolution Support
Supports up to 4K resolution -
DisplayPort Specification
DisplayPort 1.2 Standards -
Cable Colour
- C2G DisplayPort M/M Cable - DisplayPort cable - 3 m
- DisplayPort cable
- Latched
- Length
- 3 m
- Connector
- DisplayPort - male
- Connector (Second End)
- Black
- Limited lifetime warranty
- DisplayPort cable
- Latched
- Length
- 3 m
- Black
- Connector
- 20 pin DisplayPort - male
- DisplayPort 1.2
