Your basket is empty
C2G 3m DisplayPort Cable with Latches M/M - Black
Whilst Stocks Last!
Clearance
Quicklinx: 9MS5WS00 Mfr#: 84402
Length: 3m
£8.17 ex VAT
£9.80 inc VAT
Express delivery Order within the next 19 hours for delivery on Monday
This cable is an ideal solution for connecting the DisplayPort output of a laptop to a computer monitor which accepts a DisplayPort input. This cable carries a digital audio/video signal and the connectors feature latches which secure the cable in the port. Support of a High Bit Rate (HBR) bandwidth means that this cable can carry up to a 4k resolution. Built to DisplayPort 1.2 standards, this cable meets the requirements of high performance applications.
C2G DisplayPort M/M Cable - DisplayPort cable - 3 m
DisplayPort cable
Latched
Length
3 m
Connector
DisplayPort - male
Connector (Second End)
DisplayPort - male
DisplayPort cable
Latched
Length
3 m
Connector
20 pin DisplayPort - male
DisplayPort 1.2
Length: 3m
Brand: C2G
Price Range Ex VAT: 0 - 50
