C2G 3m Cat6 550 MHz Snagless Crossover Cable - Black
Quicklinx: 6BSGWS00 Mfr#: 83543
Cables To Go's Cat6 crossover cables are perfect for distributing data, voice, video and connecting network switches and hubs without an uplink port to other switches and hubs. These 550MHz rated patch cables ensure that you always have the necessary throughput to handle bandwidth-intensive applications. Note:These cables are for 10100 ethernet only and will not work for gigabit ethernet as only two pairs of this cable are crossed.
Our new moulded, snag-free "clip" prevents unwanted cable snags during installation and doesn't impair the ability to insert and remove the connector from the port. It also provides extraordinary strain-relief, so that the cable is not damaged even when pulled excessively.
  • Enhanced connectivity
    The Cat6 Booted Unshielded (UTP) Crossover Patch Cable by C2G is designed with gold-plated RJ-45 connectors to ensure stable connectivity. The use of high-quality materials ensures efficient data transfer and durability.
  • High-speed performance
    With a tested frequency of up to 550 MHz, this crossover cable is built to support high-speed network applications. Its Category 6 rating ensures that it can handle bandwidth-intensive operations efficiently.
  • Durable design
    Featuring a PVC jacket and an American Wire Gauge (AWG) of 24, this cable is crafted for both flexibility and strength. Its robust construction makes it suitable for various environments, ensuring long-lasting performance.
C2G Cat6 Booted Unshielded (UTP) Crossover Patch Cable - crossover cable - 3 m - black
Crossover cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Molded, snagless, stranded
Length
3 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
24
Plated Connector
Gold
Length
3 m
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 550 MHz
