C2G 3m (10ft) USB C Cable M/M - USB A 3.0 (3A) - Black
Quicklinx: DWR6WS00 Mfr#: 88833
Length: 3m
Select:
Hurry, only 2 left in stock!
£15.06 ex VAT
£18.07 inc VAT
The USB-C to A 3.0 Male to Male Cable is the perfect solution for connecting any standard USB-C enabled device, such as a Chromebook, laptop, tablet or smartphone, to a USB-A device, accessory or peripheral up to 10ft away for fast charging and high-speed data transfer. Whether you're desk-based or on-the-road, this one-cable solution ensures that your USB-C equipped device is fully charged and ready to go with the 3A charging output, whilst simultaneously transferring photos, music, or data at speeds up to 5 Gbps. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port.
  • Colour
  • Connector 1
    USB-C Male
  • Connector 2
    USB-A Male
  • Warranty
    5 years
  • Length
    3 Metres
C2G 3m (10ft) USB C Cable - USB A 3.0 (3A) - M/M USB Type C Cable - Black - USB-C cable - 3 m
USB-C cable
Sync and charge
Length
3 m
Connector
24 pin USB-C - male
Connector (Second End)
9 pin USB Type A - male
Rated Current
3 A
USB / USB 2.0 / USB 3.0
3-year warranty
USB-C cable
Rated Current
3 A
Plated Connector
Nickel
Sync and charge
Length
3 m
Connector
24 pin USB-C - male
USB / USB 2.0 / USB 3.0, USB-IF, UL 2725, RoHS 2 (2011/65/EU)
3-year warranty
Length: 3m
Brand: C2G
Price Range Ex VAT: 0 - 50
