C2G 3ft C14 to C19 250v 14AWG
Quicklinx: D0C1WS00 Mfr#: 80570
This power cord is the ideal solution for powering a server or connecting to a PDU in a data center or network wiring closet. This cable is able to support up to 250 volt connections and features 14AWG condutor construction. The fully molded design provides for maximum durability and long life.
  • Colour
  • Warranty
    Lifetime
  • Connector 1
    C14 IEC
  • Connector 2
    C19 IEC
C2G 14 AWG 250 Volt Power Cord - power cable - IEC 60320 C19 to IEC 60320 C14 - 91.4 cm
Power cable
Molded
Length
91.4 cm
Connector
Power IEC 60320 C19
Connector (Second End)
Power IEC 60320 C14
Rated Voltage
AC 250 V
Rated Current
15 A
Power cable
American Wire Gauge (AWG)
14
Rated Voltage
AC 250 V
Rated Current
15 A
Molded
Length
91.4 cm
199 g
Connector
Power IEC 60320 C19
Power IEC 60320 C14
