Cost-effective solution that provides high bandwidth and transmission rates over longer distances. With SC to ST termination, this high quality fibre optic patch cable is specifically designed for Gigabit Ethernet applications. The Low Smoke Zero Halogen (LSZH / LS0H) jacket is composed from materials that lessen the smoke and halogen emissions when the cable is exposed to extreme temperatures. This reduces the amount of harmful toxic and corrosive gases that cabling made with plastic materials would otherwise emit into the air during combustion. This construction makes LSZH cables ideal for use where the protection of people and equipment from harmful corrosive gases is absolutely critical. The patented injection moulding process provides each connection greater durability in resisting pulls, strains and impacts from cabling installs. Each cable is 100% optically inspected and tested for insertion loss before you receive it. A pull-proof jacket design surrounds the popular 9/125 Single-mode fibre, immune to electrical interference.
- C2G SC-ST 9/125 OS1 Duplex Singlemode PVC Fiber Optic Cable (LSZH) - patch cable - 30 m - yellow
- Patch cable - OS1
- Technology
- Fibre optic
- Type of Fibre Optics
- Singlemode
- Halogen-free
- Length
- 30 m
- Core / Cladding Diameter
- 9 / 125 micron
- Connector
- 2 x ST single-mode - male
- Connector (Second End)
- 2 x SC single-mode - male
- Yellow
- Limited lifetime warranty
- Network Cable Type
- Patch cable - OS1
- Technology
- Fibre optic
- Singlemode
- Jacket Material
- Low Smoke Zero Halogen (LSZH)
- Fibre Qty
- 2
- 9 / 125 micron
- Halogen-free
- Length
- 30 m
- Yellow
- Connector
- TIA/EIA-455-171A
- -20 °C
- 70 °C
