Product
C2G 30m DB25 M/F Extension Cable
Quicklinx: 682PWS00 Mfr#: 81404
Length: 30m
£36.19 ex VAT
£43.42 inc VAT
Easily extend your cables at a lower cost than buying a new cable. All 25 lines are wired straight through pin-to-pin for ease of compatibility. Each cable is foil shielded for EMI/RFI protection, and is available fully snagless with thumbscrew connectors for a fast, easy connection every time.
C2G Extension Cable - serial / parallel extension cable - 30 m
Serial / parallel extension cable
Shielded
Molded, thumbscrews
Length
30 m
Connector
25 pin D-Sub (DB-25) - male
Connector (Second End)
25 pin D-Sub (DB-25) - female
Shielded
Molded, thumbscrews
Length
30 m
Connector
RoHS
Length: 30m
Brand: C2G
Price Range Ex VAT: 0 - 50
