Your basket is empty
C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue
Quicklinx: 9N1RWS00 Mfr#: 89930
Length: 30m
Colour: Blue
16 in stock
£41.04 ex VAT
£49.24 inc VAT
Standard delivery Delivered within 3-5 working days
This Booted Shielded Cat6a patch cable is ideal for use with 10GBase-T ports and equipment, such as network adapters, hubs, switches, routers, DSL/cable modems and patch panels, and will protect a high speed 10 Gigabit network connection from noise and electromagnetic interference. For voice/data/video distribution, this cable will handle bandwidth-intensive applications and drastically reduces both impedance and structural return loss (SRL). Each patch cable is fully tested to meet ANSI/TIA 568 C.2 Cat6a component requirements. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality cable and plugs, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily color-coded a network installation. Each cable is individually labelled with the length for ease of use.
C2G Cat6a Booted Shielded (STP) Network Patch Cable - patch cable - 30 m - blue
Patch cable - CAT 6a
Shielded twisted pair (STP)
Shielding Material
Aluminium foil
Wires per Cable
8 wires
Molded, snagless, stranded
Length
30 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Network Cable Type
Shielding Material
Aluminium foil
Jacket Material
PVC
American Wire Gauge (AWG)
26
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
30 m
Blue
Connector
RJ-45 - male
RJ-45 - male
UL 94 V-0
Length: 30m
Colour: Blue
Brand: C2G
Price Range Ex VAT: 0 - 50
