Experience 4K ULTRA HD displays with this USB-C to DisplayPort Adapter Cable which provides a fast and reliable connection between a USB Type C enabled Chromebook, laptop, tablet, smartphone or other device, and the DisplayPort input of a projector or display – making it an ideal solution for the office, work space applications or classrooms. This adapter utilises the audio/video capabilities built into USB Type-C ports to feed an audio/video signal to a DisplayPort monitor to achieve high quality, 4K (ULTRA HD) video image. Additionally, the USB-C connector has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port. The cable form factor of this adapter provides a simple and convenient solution that eliminates the need for a separate adapter or additional cabling, offering a straightforward installation.
- C2G 3.7m (12ft) USB C to DisplayPort Adapter Cable White - 4K Audio / Video Adapter - external video adapter - white
- External video adapter
- Bus Type
- USB-C
- Max Resolution
- 3840 x 2160
- DisplayPort (male connector)
- Length
- 3.7 m
- Enclosure Colour
- White
- 3-year warranty
- Bus Type
- USB-C
- Graphics Engine
- Chrontel CH7213A
- Max Resolution
- 3840 x 2160 at 30 Hz
- Plug and Play, Directive 2011/65/EU
- Length
- 3.7 m
- 161 g
- Enclosure Colour
- White
- Limited warranty - 3 years
- 0 °C
- 50 °C
- 25 - 70%
