Product
Brand
C2G 2m Value Series™ High Speed HDMI® with Ethernet
Quicklinx: 7ZDVWS00 Mfr#: 82005
Type: HDMI
Length: 2m
£8.33 ex VAT
£9.99 inc VAT
Express delivery Delivered on Tuesday
Perfect for your 3D and HDMI Devices
Choose Value Series and make the right choice to connect the HDMI signal from your DVD player to your TV or projector. This quality-made cable delivers a crisp, clear audio/video signal for less. This cable type offers the same baseline performance as the high speed HDMI cable, plus an additional, dedicated data channel, known as the HDMI Ethernet Channel, for device networking. HDMI Ethernet Channel functionality is only available if both linked devices are HDMI Ethernet Channel-enabled.
The cable's construction provides the quality needed for a clean 1080p picture. Gold-plated connectors ensure long-lasting, dependable connections while the PVC jacket adds flexibility and durability. The fully molded connectors provide excellent strain relief.
  • Connector 1: (1) HDMI (Type A) Connector
  • Connector 2: (1) HDMI (Type A) Connector
Product Specifications
  • Color: Black
  • UPC: 757120820055
  • Warranty: Lifetime
  • Vendor: Cables To Go
  • Weight: 0.109 KG
  • Length: 2.00 Meter
  • Volume: 392.0 CCM
C2G/Legrand Select High Speed HDMI Cable with Ethernet - HDMI with Ethernet cable - 2 m
Cable
Length
2 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
HDMI Ethernet Channel (HEC), HDMI CEC support (Consumer Electronics Control), moulded
Cable Type
Jacket Material
PVC
Length
2 m
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
Limited warranty - lifetime
Type: HDMI
Length: 2m
Brand: C2G
Price Range Ex VAT: 0 - 50
