Connect to mobile phones, GPS systems, PDAs, OTG devices and digital cameras by using the micro-USB connection on your computer or other USB device. Its small form factor is ideal for today's compact portable devices while easily transferring data or charging your device at a high transfer speed.
- C2G - USB cable - USB to Micro-USB Type A - 2 m
- USB cable
- USB On-The-Go
- Length
- 2 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 5 pin Micro-USB Type A - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB cable
- USB On-The-Go
- Length
- 2 m
- Black
- Connector
- USB / USB 2.0
