Just plug-and-play for keyboards, mice, modems, printers, and other USB peripherals. This cable provides a transfer rate up to 480 Mbps depending upon the peripheral's USB version, and easily attaches to any USB device. Foil and braid shielding reduces EMI/RFI interference and twisted pair construction helps reduce crosstalk thus ensuring high speed, error-free data transfer. Please Note: This cable is not intended to connect two computers together or to connect a USB hub between two computers. Doing so may cause irreparable damage to your computers. We offer a USB file share cable (#81635) to connect two computers.
Product Colour
Black -
USB Support Specification
Supports high speed USB 2.0 devices (480 Mbps), and is backwards compliant with full-speed USB 1.1 (12 Mbps) and low-speed USB 1.0 (1.5 Mbps) -
Compatability
PC and Mac compatible -
Transfer Rate
- C2G USB cable - USB to USB - 2 m
- USB cable
- Technology
- Double shielded twisted pair
- Length
- 2 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- USB / USB 2.0
- Black
- USB cable
- Technology
- Length
- 2 m
- Black
- Connector
- USB / USB 2.0, Plug and Play, RoHS
