C2G 2m USB 2.0 One B Male to Two A Male Y-Cable
Quicklinx: 63T1WS00 Mfr#: 81578
Increase the power running to a portable hard drive from your PC or Mac! When a standard USB cable cannot transfer enough power to operate an external device, such as a portable hard drive, you need a USB 2.0 Y-cable. Simply plug this cable's USB B end into the device, and then plug the two USB A ends into open USB ports on one desktop PC or Mac. This cable then pulls power from both USB ports, and thus increases the output to the external drive.
The molded hood on the auxiliary USB A connector enables the user to quickly distinguish between main and auxiliary power. Foil and braid shielding reduces EMI/RFI interference, and twisted pair construction reduces crosstalk for high speed, error-free data transfer. This cable is compatible with USB 1.0, 1.1, and 2.0 specifications.
C2G "Y" Cable - USB cable
USB cable
Double shielded
Molded
Connectors
4 pin USB Type B - male
Connectors (Second End)
4 pin USB Type A - male , 4 pin USB Type A (power only) - male
USB / USB 2.0
USB cable
Double shielded
Molded
Connectors
USB / USB 2.0, RoHS
